USB to RS232 adapters
Beaucoup
Post by Beaucoup »
I plan to embed an LK162-12 16*2 LCD in my USB keyboard :smile: The keyboard's got an internal USB hub with a spare channel and plenty enough power to drive and backlight the display, but this will obviously require the use of a USB to Serial adapter. Can anyone reccomend such an adapter that will work in a relitively painless fashion with this display under Linux? Obviously, smaller is better, since this thing's getting shoved into a small space, but any setup that has been tested to work is worth noting.
-Andrew
Beaucoup
Post by Beaucoup »
Well, I found one that seems to work; a cheap generic brand PL2303 based adapter, which, once stripped down, fit easily in the small space. It also helped that it didn't require an external power supply.
Here's the finished project, horriffic Dremeling included. To get everything to fit, I had to remove the display's serial backpack, and reconnect it with a nice long ribbon cable, after removeing all the connectors and headers from it. I completely Dremeled off the GPO's, and also took a few millimeters off the display's PCB itself, completely destroying any imagineable warrenty this thing may have had :-P
The connections are soldered via the USB-to-Serial adapter directly to the keyboard's internal USB hub, and powered off the same, so there are no external connections. It seems so far to run under both Linux and Windows XP as well as if it were connected directly via serial(except with LCDProc, apparently due to a bug that some other people have seen as well).
http://24.88.123.54/tempshare/lcd3.jpg
The cutting is a bit sloppy to look at, but given that this is the first mod I've done which was more sophistacated than putting LEDs in things, I'm satisfied with the way it came out. :-)
-Andrew
GarrettWG
Post by GarrettWG »
I think you should add the picture to the gallery section! And believe me I went through 3 3.5 adapters to get mine in so don't feel bad :smile:
gordy_hand
Post by gordy_hand »
-Andrew
I used one for my new lcd and it works a treat . Where are you based if its in the uk I can give you a link to the product I used :smile:
Beaucoup:
Aside from the dremelling, that's pretty damn sweet!!!
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Nice work... I'd appreciate links to usb-serial convertors in any countries (for my faq), cheers,
Rob.
Beaucoup
Post by Beaucoup »
I'm in the United States; I got the adapter cable from a locally owned retailer here(CompuForce, http://www.cforce.net/). The device is made by a company called Manhattan, and seems very similar to high-speed USB to RS232 adapter that Keyspan makes, except this one only set me back $30 US :-).
Steve Ryan
Post by Steve Ryan »
Hi to u all this is my first post i'm waiting for the arrival of my display i got my serial to usb adaptor from the UK http://www.greenwicheshop.com
gordy_hand
http://www.maplin.co.uk/default.php? have a couple of them in stock :smile:
Gordy_Hand
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Thanks for the links...
r.
