Hi there
I purchased an ELK204-7T-USB-GW-PL display a couple of months ago - really happy with it, it works great, BUT, one of the indicator LEDs has stopped working.
The middle tri-color LED no longer illuminates green - so it will only show red, not green or yellow.
I suspect the fault is with the tri-color LED itself - is it possible to replace the LED?
Many thanks
Will
Replacing indicator LED for ELK204-7T-USB-GW-PL ?
Re: Replacing indicator LED for ELK204-7T-USB-GW-PL ?
Hi Will,
Glad to see the ELK unit is working well for your application, except for that middle indicator LED.
If you could send me a PM with the serial number of that unit I can provide additional details regarding repair.
Just wanted to thank Troy and the Matrix Orbital team for a speedy resolution to this issue.
Fantastic customer service!
