Set font using C#, version 8.5
PaulBMO
Post by PaulBMO »
I've got an Visual Studio 2013 C# application to control the EGLK19264A-7T-USB-WB-PL display.
All worked fine with version 8.4. Now I have a big problem with setting the font ID using version 8.5.
All other commands I send to the display work fine.
Can you help me?
And could you please supply me with some example code?
Kind regards,
Paul
With kind regards,
Paul Joosten
BMO Offshore Measurements Systems BV
Rotterdam, the Netherlands
Re: Set font using C#, version 8.5
Hi Paul,
Your Set Current Font issue is likely due the change we made to increase the Font ID parameter size to two bytes at firmware revision 8.5. You can find more information about all changes to the GLK19264A-7T-1U firmware here.
PaulBMO
Post by PaulBMO »
Thanks Troy. I got it working.
With kind regards,
Paul Joosten
Good to hear Paul, my apologies for the inconvenience.
