NEW HTT Firmware R2.1.11951
HTT Series HDMI Interface TFT's
New firmware has been released for PCB Revision 1.5+ and 3.0+, available here:
https://www.matrixorbital.com/firmware/htt-firmware
New Features including, Haptic feedback, piezo Buzzer for alarms and touch feedback, multistage backlight dimming, and other new features.
--haptic [duration]
set duration for haptic feedback (in 100ms increments)
for 1 second - use 10
--piezo [duration]
set duration for piezo tone at 400Hz (in 100ms increments)
--alarm [type] [duration] [flash]
The alarm will continue until either one of the folowwing conditions occurs:
- The duration of the alarm is reached
- The screen is touched (touch capable models only)
- The alarm is canceled by selecting alarm type 0
type: 0-17 alarm type [0 = off], 16 preprogrammed tones
duration: duration for the alarm (in 100ms increments, for 1 second - use 10), use -1 for no timeout
flash: flashes per second, max = 10, off = 0
--touchfeedback [setting]
Setting: 0 none, 1 haptic, 2 piezo, 3 haptic and piezo
--touchdim [time1] [brightness1] [time2] [brightness2] [time3] [brightness3] [time4] [brightness4]
dim the display after [time] seconds of inactivity up to 4 levels.
[time1] [0-600] time in seconds since last touch
[brightness1] [0-255] brightness of the display 0 = Off, 255 is full brightness
[time2] [0-600] time in seconds since [time1]
[brightness2] [0-255] brightness of the display 0 = Off, 255 is full brightness
[time3] [0-600] time in seconds since [time3]
[brightness3] [0-255] brightness of the display 0 = Off, 255 is full brightness
[time4] [0-600] time in seconds since [time4]
[brightness4] [0-255] brightness of the display 0 = Off, 255 is full brightness
--touchdim 5 150 30 75 60 25 0 0
example 3 stages, in 5 seconds brightness will be 150, 30 seconds after that 75, 60 seconds after 25
--touchdim 0 0 0 0 0 0 0 0
disable feature
Note: while time is specified in seconds, for convenience time can be postfixed with the letter 'm' for specify minutes ie 5m would automatically convert to 300 seconds.
--factorydefaults
reset the unit to factory defaults
