Emulation of EVEx on a PC screen
rascalito
Post by rascalito »
Hello!
I would like to know if there is some kind of emulation system for PC. Here is why:
I wrote a software for a real EVE, but now I need to write a user's manual.
I could of course take pictures (and that's what I am doing). But the problem is that
pictures are always a little bit distorted, there is a reflection on the screen, contrast
is not that good, etc, etc. So ideally I would like to run the software on a PC to get
the exact same image that I can dump into an image of some kind.
Does this exist?
Thanks for any hint,
R
Re: Emulation of EVEx on a PC screen
Maybe use the EVE Screen Editor and "create" the screens you want to take a screen shot of?
Bridgetek has an emulator available, you can find details in appnote AN-281 [1]
[1] https://brtchip.com/wp-content/uploads/ ... _Guide.pdf
rascalito
Post by rascalito »
Hello!
Thanks for your replies.
Yes, that's the idea. I would like to dump the buffer I'm sending by SPI / DMA on the real hardware,
then feed the emulator with it, and get the exact same screen on my PC.
I have checked the AN281 and downloaded it.
Now it says this:
"The emulator library is included in the install package of the EVE Screen Editor, which can be
found in the section of the following page:
http://www.ftdichip.com/Support/Utilities.htm"
I have checked the page, searched for "emu" no results, for "screen editor", then "screen" only... No results.
Where can I download the library from?
I have also searched the web for "FT8xx emulator", found some pointers to AN281 above.
Any hint welcome
R
It's included in the sample applications over at [1] since the download link somewhat gets lost in that page i'll link the current version as of today directly [2]
[1] https://brtchip.com/SoftwareExamples-eve
[2] https://brtchip.com/wp-content/uploads/ ... .2-rc3.zip
