About EVE4
rascalito
About EVE4
Post by rascalito »
Hello!
I was looking at EVE4x-70G-IPS, and it says 32 Mb or 128 Mb.
Is it megabits or megabytes (I suppose it's megabit, but I would like to be sure.
Next: what is the USB COMM? I mean, is it an on-board addon allowing to connect
directly with a USB port (and therefore having an out-of-box run of the LCD?
Or is it an external board communicating with the LCD board?
Is there any documentation describing these features (with pictures showing
the differences). Well I should have started with this question since it would probably
reply to the others.
Thanks for any hint!
R
Re: About EVE4
Mb, so Megabit
The USB allows you to connect it direct to USB using the FTDI FT232HL bridge.
Take a look here at example code
https://github.com/MatrixOrbital/EVE-Wi ... map-Viewer
