Call startup screen when PC powers off
madz
Post by madz »
I have a LK204-7T LCD panel which I've set a startup screen using the '2.2 Change the Start Up Screen' described in the manual.
When I power off the PC I want the LCD panel to display the startup message, instead it gets stuck on whatever is last shown in the panel.
How do I make it show the startup screen instead?
Re: Call startup screen when PC powers off
Hello Madz,
I wonder if you please give Boot Logo a try:
https://www.matrixorbital.com/index.php ... et&did=543
First configure the Serial Port; then the Display Size (4x20).
Make your changes - write what you want for your start up screen; edit the custom characters if desired.
You will see that your changes are applied on the screen. Click Write to Display.
Cycle power on the display and your startup screen should be displayed.
Let me know how it turns out.
madz
Post by madz »
Thanks, that helped
Glad to hear!
-Raquel
