Change Label Text
Posted: Sat Oct 28, 2023 4:54 pm
by robertwr14
Hi
I'm looking for an example of C code showing
how to get my micro's uart to change the text
on a dynanic label
Robert
Re: Change Label Text
Posted: Mon Oct 30, 2023 2:48 pm
by Raquel
Hello Robert,
Thank you for contacting Matrix Orbital technical support.
I assume that you created your dynamic label using GTT Designer Software.
You may check Report.txt in the output folder of your GTT Designer project to see the command needed to change the particular dynamic label.
If not, you can use the Update a Label Command (you have options on data format). Please consult the manual for more details.
