lcdc hotkey help
tweak-freak
lcdc hotkey help
Post by tweak-freak »
ok I would like to setup a hotkey to turn the backlight on/off
I don't have the option of on and off both just one or the other...
Cheese told me to use the command Backlight on/off
I do that but it doesn't work?
any help?
Mat-Moo
Post by Mat-Moo »
You should be able to set up One event using one hotkey to the event "DSP->Backlight On/Off" which will toggle it (providing you have the latest version as there was a bug in .20 I think).
tweak-freak
thanks...thats what it needed...I didn't have the Dsp- >
Mat-Moo
Post by Mat-Moo »
Good show :)
TAG
Post by TAG »
I use LCDC 1.02 build22 on a GLK12232-25sm and backlight off doesnt work for me
it works fine from the test area in configuration panel, but wont work @ all from the events ....
does turning it on and off with MOGD work?
TAG
Post by TAG »
Yes work fine in mogd
but if u look @ my post in the hardware forum you will see this is only a minor problem for me right now ...
TAG
Post by TAG »
Backlight OFF actually works if i trigger it w/ a keypad press, but it wont if i trigger it w/ an on_finish event ... its very weird ... backlight intensity has no effect in the lcdc configuration (tried it coz i thought intensity 100% in the config was actually the problem for my on finish event ... making it bright whenevr lcdc was on) .... that backlight problem is probably more a problem for mat to solve though...
I noticed something i hadnt seen b4 on my LCD .... maybe its me but i think its getting black on the right side where the led is ... cant see the led from where i am since its mounted into my comp but i dont think that black patch was there ... still works though
TAG
Post by TAG »
that patch dissapears if i turn backlight off but comes back i turn backlight on .... a shadow ? the thing is i hadnt noticed it b4 ....
Mat-Moo
Post by Mat-Moo »
The GLK at present does not have back light intensity capabilities, only on/off. I have an event "SYS->On Finish" "DSP->Backlight Off" which works correctly
