LCDC Error, hardware or software?
Do you currently have any other USB devices connected?
WinoOutWest
Post by WinoOutWest »
Miles wrote:Do you currently have any other USB devices connected?
I have 6 external and 2 internal m/b USB ports and the only thing plugged in currently (not that it seems to have made a difference in the past) is I have a USB IR Receiver/Transmitter plugged into one of my external USB ports. Also I have ran the module off the internal USB connection of the m/b and a normal external USB connection with seemingly no effect either way on my problem.
There very well might be a problem with the FTDI component on how it receives and transmits data. To do a further analysis I would have to perform some tests on our test bench. Can you contact me at myero@matrixorbital.ca to discuss some RMA options?
Phish
Post by Phish »
Miles wrote:There very well might be a problem with the FTDI component on how it receives and transmits data. To do a further analysis I would have to perform some tests on our test bench. Can you contact me at myero@matrixorbital.ca to discuss some RMA options?
Is there any update on a possible resolution to this problem? I'm having the exact same issues with my MO display, and I can't seem to make it run stable on my system regardless of what I do.
WinoOutWest
Phish,
I RMA'd my module - Miles tested it for two days without error. I received it back from RMA and it errored out again within 5 minutes. To make a long story short I changed my USB port that I was plugged into and it has been working for over 2 days now without a problem. So I am starting to think that there is a problem with one (or several) of my USB ports. I would try your module on another machine if you can. Try to eliminate the USB as source of the problem...
Cheers!
Wino
Phish
Post by Phish »
WinoOutWest wrote:Phish,
Cheers!
Wino
Wino,
What motherboard are you using? I have a MSI 865PE Neo2-PFIS2R, and I'm pretty sure the board is the problem, since I have 2 of these displays, both exibit the same behaviour, regardless of USB port used. I've also installed a bare-bones instance of XP and removed every item in my system other than CPU, Vid card, RAM and PS2 keyboard/mouse. I'm going to try another motherboard tonight to see if that solves the problem, and if so I'll RMA the MB back to MSI
WinoOutWest
Phish,
My board is an Asus P4P800-VM. I didn't think to try it in another board yet. But after months of problems its been stable for 3 days now. I might even begin to get excited at the prospect of this thing working now!
The only thing different since it "started" working was the USB port that its plugged into.
Zwitta
Post by Zwitta »
I got a similar looking error.. not sure if it was exact tho, when i was using the ping plugin on LCDC, I just stopped using it. Are any of you using that plugin?
Mike
