Anyone use DeVaSys USB to I2C Interface?
JohnCox
Post by JohnCox »
I found this $79 USB to I2C interface board on the web and was wondering if anyone has ever tried to use it with Matrix Orbital's LCDs.
Henry, if you have a few seconds, could you take a look at the specifications on their website to see if it looks viable? The features listed include "90Kbps I2C interface, onboard 16KB I2C eeprom, 5 pin connector for attaching external I2C hardware. "
Link: DeVaSys USB I2C-IO Interface
Link: More detailed image
Aniso
-=Beloved by all=-
-=Beloved by all=-
Post by Aniso »
Seems like it would work fine... Depends on if you can make it not bitch about ACKs and stuff. Maybe I didn't read the question - why USB to I2C?
JohnCox
Post by JohnCox »
I need to hook up ten displays to a laptop, so I thought I2C would be the way to go.
flyguy
Post by flyguy »
Just saw your post.
I have the Devasys USB I2C/IO currently hooked up on one of my XP machines talking to two MO LCD2041's and an OOPIO-R over I2C. So far everything thing seem to be working fine. All you need to do is add 1 to the HEX address of the LCD & off you go. The routines in the Devasys api work great. I am using BCB+ v5 with no issues.
Regards,
Jay :)
Pheonix
Post by Pheonix »
I may be missing the point here, but with the new USBs, can't you hook upto 127 up? So just get a small USB Hub?
flyguy
Post by flyguy »
With I2C I can connect as many LCDs on a single connection as allowed by the particular device(16-127) & some other devices all on a singe USB connection to the PC.
If I have read the USB doc correctly you can connect 100 LCD devices to a single USB host, which means you need HUBS. For my application, besides the cost of the 10 LCDS I would have to purchase and deal with USB Hubs that support at least 10 connections + what ever is necessary to connect to the pc AND interconnect the hubs. In addition to the hardware you would need the software/drivers/sdk to talk to the LCDS from your application, which I do not believe has been released yet.
JohnCox
Post by JohnCox »
Im dusting off this old project of mine that requires ten(10) LK204-25s to be linked together. Is I2C the most economical way to go?
I haven't purchased the LCDs yet, so I could go the USB route.
It would also seem that I2C would be easier to implement in software, since only one connection would need to be managed.
