I have a new MX411 installed on a dual Xeon workstation (IWill DH800 Motherboard). I had everything working for one day with two temperature probes. I added a third temperature probe and have had problems ever since. When I attempted to scan the temperature bus, I detect hundreds of probes. I read the postings here and started removing probes to find the bad probe, but that doesn't seem to be the problem. I can remove all the probes and I still detect tens to hundreds of probes. Furthermore, whenever I scan the temperatuere bus, the USB connection dies. (I don't get an error to that effect at the temperature bus screen, but I do get communication errors if I attept to start the display or if I do an autodetect at the general configuration screen. Com3 is my communication port and it cann't be found after running a temperature bus scan.) If I shut the machine off and then start back up the display and LCDC work fine until I try to scan the temperature bus again. Any suggestions as to what my problem might be?
Thanks.
Temperature Bus Scan Errors
Mike Maxwell
