Questions about Dremel tools moding your case.
David9799
Post by David9799 »
Just wondering what Dremel tools you use to cut your case with? I want to make a place for my MX4. Looking in the gallery everyone used a Dremel to cut with. How do you get everything so stright and accurate?
Bernie
Post by Bernie »
Hello, sorry for the long delay with a reply. Dremel tools is not my expertise. I was hoping some of our customers with more experience in this area may have been able to respond but it seems not so. I hope you were able to find a solution.
Best regards,
Bernadine
Dgephri
Post by Dgephri »
ah, a new Dremel purchaser. You should Google up on some Mod Guides, how-tos and such.
Some basic tips:
Use the Fiberglass Reinforced cutoff wheels. They are flexible, narrow, and resist wear much better than the hard stone-type cutting disks.
Cover the area around the work with Masking tape. This serves to prevent accidental scratches, and allows you draw on your surface without leaving permanent lines.
Cut INSIDE the line, but very close. I prefer to file up to it, rather than cut too much. There is much post-cut work, so take your time, and do it right.
Measure twice, then measure 2X again, then consider measuring again, then cut ONCE. :) Good luck, we all feared out first cutting!
Bernie
Post by Bernie »
Thanks Dgephri, that was the kind of response I was hoping someone would respond with......
Thanks again for your assistance and helping this customer out!
Bernadine
Dgephri
Post by Dgephri »
no problem at all...you guys at MO are all so helpful, I figured I can chime in with some modding pointers. :)
just for reference, even though most of the nicks I see here are there too...have a read over at:
www.gruntville.com
www.bit-tech.net
oh, geez, so many others, HardOCP, Modfathers, casemodgod, etc. do some googling and start reading.
have fun, be careful, wear eye protection! ouch.
deadly-app
Post by deadly-app »
Another idea would be a jigsaw, a little rougher cut, but straighter :)
I just used a dremel to slice up my drive bay for my praetorian to fit my MX211, I cut to within a few millimeters of the line and then filed it the rest of the way.
Everyone check out Comp-Reviews for all your hardware review needs.
