I have a VK204-24-USB installed but can't seem to get it to work. It is powered and displays the default screen, but I can't change the display. I have installed the 1.4 usb drivers and it gives me a com3, but lcdc won't detect the display . I have also tried using HyperTerminal to talk directly to com3, but that doesn't work either. I have tried several usb ports and cables as well.
Any suggestions?
Thanks.
Trouble communicating with a VK204-24-USB
Hi Wiley,
If you email me at tlam@matrixorbital.ca, I will send you a copy of uproject.
Tom,
When running the Display Tuner R. v0.7 application, the Autodetect button on the Com Setup tab never detects anything. If I manually set it to COM3 with a baudrate of 19200 and click Open COM the Connection Status lights up blue.
On the main tab if I click on the Clear Display or type in some text and click Send Text nothing happens. The display still shows the startup screen.
The keypad however does seem to work. When I press the buttons the hex values show up in the text area on the right.
Any ideas?
Wiley
Any ideas?
Wiley
