Hi all, I brought an LK204-25 along time ago, its been doing various things in various computers. But now it has a place to live, in my (half made) HTPC, problem is it's a 7v - 15v version (normally plug it into PC 12v), but I want to run it off the 5v Standby voltage, so it can display things while the pc is off/booting/shutingdown etc. How do i mod this to use 5v (i would like to if possible still be able to use 7-15v again in the future, but if not possible i prefer 5v only)
Thanks for ur help
LK204-25 12v -> 5v
Hi DieCastBlue,
You will be able to convert the unit back to a 5V unit. I have attached a picture to illustrate what you should do to convert the unit. You should keep the components you removed, so you can convert the unit back in the future.
- 5V conversion.jpg (48.15 KiB) Viewed 3340 times
Hello DieCastBlue, thank you for posting. Please note, if you decide to make the changes, as mentioned by Tom, it will void your warrenty. I realize your unit purchase is dated back.....but I thought I should make you aware of this before you make the decision to convert voltages.
Regards,
Bernadine
Regards,
Bernadine
