Will the Aquatube thermal sensor probe and LED work with any of the LCD display?
Hi revlimit,
Thank you for posting on the forums.
Sorry, the Aquatube thermal sensor probe won't work. The only temperature probes that will work with our units are the dallas one wire protocol. The temperature probes we provide are the DS18S20, which can be found at http://www.matrixorbital.com/product_in ... an-cooling
However, if they are just standard LEDs, you can connect them to any of the displays.
For you applications, I recommend purchasing any of the MX series displays. For more detailed information a MX series display, you can refer to one of the manuals at http://www.matrixorbital.ca/manuals/LK_ ... SB_140.pdf
Thanks for the response. Unfortunately, I need a water temp probe.
Tom wrote:Hi revlimit,
