Moderators: Henry , Mods
LCD user
Posts: 13 Joined: Mon Sep 26, 2005 7:59 pm
Post
by LCD user » Mon Sep 26, 2005 10:25 pm
I'm just learning how to use this but when I select "Start Display" all my fans immediately turn off. Why does it do this and how do I make it stop?
Posts: 1030 Joined: Mon Jul 19, 2004 4:43 pm
Post
by Tom » Tue Sep 27, 2005 10:27 am
Hi LCD user,
Thanks for posting on the forum.
The reason why your fans turn off because you don't have the fan options set up, so the fan will start at 100%.
I have attached a picture on how the configuration should be onr LCDC below.
LCD user
Post
by LCD user » Fri Sep 30, 2005 10:06 pm
I've had everything set for the fans just like you told me. It was working but now it turns them off again as if it reset itself. It has the same settings though. ?
Post
by Tom » Mon Oct 03, 2005 9:22 am
What have you set in screen builder?
LCD user
Post
by LCD user » Mon Oct 03, 2005 5:18 pm
Hi Tom,
I just have four screens I've been working on. For weather and system info, although I don't have much going on in the system info one because the last plug-in (speedfan) I tried had no temp readouts. So, not much. What do I need?
thanks
Post
by Tom » Tue Oct 04, 2005 9:12 am
What happens when you program an event, so that on LCDC startup, the fans turn on?
