I am displaying a graph drawn as vertical lines and updating about 3 times per second at the end of a 10 foot cable. I am using RS232 and rev 1.4. Suddenly the back light fails after many hours (<10). My power comes from a 24VDC power supply through a 5 V switching reg.
The backlight LED is fine and sometimes mogd will bring it back but that is hit-and-miss because my comms are screwed up. Mogd.exe cannot even print the test message. I get a few garbled chars instead.
My environment is generators and inverters, no power lines on site.
I am set up at least 60 feet from the inverters and 3-phase generators are the quietest electrical source I know.
I have tried the manual override but no luck. Is there a deeper reset function or is my display hopelessly gibbled? So far I have damaged three units on this project. Any hints would be apprreciated.
