hai iam new to this forum, and iam glad to see so many good people out there to share their knowledge.
Well i have a lcd module with built in controller(LC7981) +memory
192x128 dot matrix lcd
the microprocessor is taking too much time inorder to dump the display information to the lcd as a result of which the processors performance is degraded. (though i refresh display ram with new display data once per sec==>tooo bad)
The increased time cause:
(1)i dont have direct access to sram, i have to access sram only throu' controller after passing suitable command words. (This has to be done for every 8 pixel of information) (192x128)/8 words has to sent. as i also have to take care of control signal i cannot use dma
If not is their any solution to solve this problem
Are there lcd modules available in the market which allows dumping of display information directly to sram rather than throu' controller (assuming sram to be dual ported ) their by reducing the load on the processor
I would be very happy if i could get a solution to increase the refreshing of display ram with new display buffer information with our affecting the processor performance
help required in increasing the refreshing of display ram
Hi harilcd,
Thank you for posting at the Matrix Orbital forum.
I'd like to help you out, but it doesn't look like you have a Matrix Orbital product. This forum is for Matrix Orbital products only. I you would like to check out Matrix Orbital products, you can refer to the main website at http://www.matrixorbital.com/
