Screen Change
q_is_back
Screen Change
Post by q_is_back »
Right guys and gals
I've had a MX412 for about 1-2 years now, works great.
What i've just done is change my setup to a black cube case and red cathodes, so I want to change the screen to a red one, instead of a blue one.
I'm fine with having to do some DIY work if need be's
Any suggestions?
-={Q}=-
Hi q_is_back,
The only way to change the display color is to actually change the display itself. You can get a LK204-24-USB-R.
q_is_back
Post by q_is_back »
Cheers for the fast response.
Yeah thats exactally what I ment, just wasn't sure which screen would fix thats all.
don't suppose the LK204-25-USB-R would fit? an extra char on the end of each line would be nice :D
whilst I'm on the subject anyway, what would be involved with the changing of screens?
just a simple unscrew and replace?
-={Q}=-
It is as easy as removing some screws with a phillips screw driver, and replacing the screen. The LK204-24-USB-R will be a perfect fit.
