Driving LED's from an advanced GPO?
stonehdl
Post by stonehdl »
I want to drive the disk I/O LCD in my case from an advanced GPO. (The low power GPO's are already in use.) I am powering the VK204-24-USB board from a floppy disk power cable, and have set the GPO's to high power (12v).
Would a 240 ohm, 1 watt, resistor in series between the middle pin (+12v switched) of the advanced GPO plug and the positive lead of the LED -- with the negative lead of the LED returned directly to the right hand pin (GND) of the advanced GPO plug -- be the correct wiring?
240 ohm
+ 12v 1 watt LED GND
o-------VVVVVV-------(+*-)--------o
Dave S.
Hi stonehdl,
You must have a really bright LED to connect it to the high power gpo. You have the correct wiring for the led.
