My brother was thinking of getting one of these and I had some questions about the LK204-24-USB(MX421):
1. Is the 12v fan controller strong enough to control 3 x 0.52amp fans?
2. Will the 2 wire water temp sensor he already has work? Click here for sensor
Pre-Sales Questions about LK204-24-USB (MX421)
Hi firengine16,
The display is capable of handling up to 1Amp current draw for each fan. So the fans you have should run no problem.
The sensor on the other hand won't be able to directly plug into our display, what do you use to read the sensor right now? Our display may be able to grab the temperature using LCDC and a plugin, from the equipment you are using right now.
jon
jon
