Script ID 256 and above wont run (Firmware 8.5)
sheetsjf
Post by sheetsjf »
I just loaded firmware 8.5 to my GLK240128-25 display to test out scripting with ID's greater than 256.
I created this .mts file to use with the MOGD# script display feature to test out a script with ID 512 (ID byte1: 0, ID byte2: 2)
SendNumeric 254 92 2 0 2 17 0 0 0
ReadByteCompare 1
SendNumeric 254
ReadByteCompare 254
SendNumeric 1
SendNumeric 88
ReadByteCompare 88
SendNumeric 1
SendNumeric 254
ReadByteCompare 254
SendNumeric 1
SendNumeric 121
ReadByteCompare 121
SendNumeric 1
SendNumeric 72
ReadByteCompare 72
SendNumeric 1
SendNumeric 16
ReadByteCompare 16
SendNumeric 1
SendNumeric 84
ReadByteCompare 84
SendNumeric 1
SendNumeric 69
ReadByteCompare 69
SendNumeric 1
SendNumeric 83
ReadByteCompare 83
SendNumeric 1
SendNumeric 84
ReadByteCompare 84
SendNumeric 1
SendNumeric 32
ReadByteCompare 32
SendNumeric 1
SendNumeric 83
ReadByteCompare 83
SendNumeric 1
SendNumeric 67
ReadByteCompare 67
SendNumeric 1
SendNumeric 82
ReadByteCompare 82
SendNumeric 1
SendNumeric 73
ReadByteCompare 73
SendNumeric 1
SendNumeric 80
ReadByteCompare 80
SendNumeric 1
SendNumeric 84
ReadByteCompare 84
SendNumeric 1
When i try and run this script with the command sequence (254, 93, 0, 2), the script doesn't run. When I change the script id to 255, 0, it works.
Are script IDs still limited to 255 or less in firmware 8.5?
Re: Script ID 256 and above wont run (Firmware 8.5)
Hi Jason,
Unfortunately, the bug fix for script IDs greater than 255 was not included in firmware revision 8.5.
We were hoping to release a couple bug fixes with some new features in a new firmware package, however, we understand that these issues need to be fixed in a timely manner. We will release a minor firmware upgrade to fix this issue shortly, I'll post an update when it's done.
Best regards,
