ATX Networks
SEAL Analytical Limited
Unit: LK204-25
Company: SEAL Analytical Limited
Website: https://seal-analytical.com
Using our LK204-25 Industrial Serial LCD with a keypad interface.
The SEAL Analytical Digestion Block is your key to successful kjeldahl digestions. The BD50 Digestion Block automates acid digestions for up to 50 laboratory samples simultaneously. It is ideal for Total Nitrogen (TKN) and Phosphorous (TP) digestion.
Noisecom
Unit: HTT70GA-TPC
Company: Noisecom part of Wireless Telecom Group
Website: https://www.noisecom.com/
Noisecom using our Industrial 7" HDMI Display with USB touch.
The Noisecom UFX7000B broadband AWGN noise generator has a powerful single board computer with flexible architecture used to create complex custom noise signals for advanced test systems. This versatile platform allows the user to meet their most challenging design requirements. Precision components provide high output power with superior flatness, and the flexible computer architecture allows control of multiple attenuators, switches, and filter banks.
NSI Inc
Unit: https://www.matrixorbital.com/lk162b-7t
Company: NSI Inc
Website: https://nsystems.com
The LK162-7T is a 16x2 intelligent LCD display designed to fit into 1U form factors. Engineered to quickly and easily add an elegant graphic HMI to any application. Multiple communication protocols such as Serial RS232, TTL, I2C, and USB communication modes allow the LK162-7T LCD to be connected to a wide variety of host controllers.
Company: NSI Inc
RF Instruments LLC
Unit: GLK19264A-7T-1U
Unit: LK162B-7T
Company: RF Instruments LLC
Website: https://www.rfinst.com/
2U 19” Rack Mountable Wideband Up –Down Converter High Performance Frequency Extender
Unit: LK162B-7T
MVG
Unit: LK204-25-IY
Company: Microwave Vision Group
Website: https://www.mvg-world.com
The AL-4164 and AL-4166 programmable controllers offer real-time control of positioning subsystems used in near-field and far-field antenna measurement systems. They may be configured to drive planar scanners and general purpose far-field positioners that are encoder-based or involve simultaneous motion.
Engineered Compost Systems
Unit: LK202-25
Unit: BEZ-202C
Company: Engineered Compost Systems
Website: https://compostsystems.com
Professional bezel for industry standard 20x2 / 2x20 LCD, VFD or OLED displays. ABS construction, with a lexan window combined with our serial 20x2 LCD.
Unit: BEZ-202C
Omniverter
Unit: BEZ-204A
Company: Omniverter
Website: https://www.omniverter.com/
Professional bezel for industry standard 20x4 / 4x20 LCD, VFD or OLED displays. ABS construction, with a lexan window.
Company: Omniverter
LDetek
Unit: LK162A-4T
Company: LDetek
Website: http://www.ldetek.com/
The LK162A-4T is a tri-color software controlled backlight, that will allow the user to set the colour of the characters on a black background.
Company: LDetek
The LDPMS is a stand-alone pressure monitoring system design to monitor the pressure of a gas source. It can monitor up to 2 gas sources simultaneously and generate an independent low-pressure alarm when the pressure level of a source is below its setpoint
Safety Vision
Unit: ELK204-7T-GW-MT
Company: Safety Vision
Website: http://www.safetyvision.com/
External 4x20 LCD in an industrial metal enclosure, 3 dual color LEDs, 7 key backlit keypad, custom silk screening.
GOMA ELETTRONICA SpA
Unit: BGK19264A-BK
Company: GOMA ELETTRONICA SpA
Website: https://www.goma.it/en/
A 5.25" 192x64 LCD in a 1 U bracket, 7 key backlit keypad, 3 dual colour LED's, Serial, I2C, RS422 or USB interface.
Kaman Precision Products
Unit: LCD0821
Company: Kaman Precision Products
Website: https://www.kamansensors.com
The Most Advanced Digital Variable Impedance Transducer for Noncontact Linear Position / Displacement / Proximity Sensing
ANTECH
Unit: MOP-TFT320240-35A
Company: ANTECH
Website: https://www.antech-inc.com
Industrial long term 3.5" 320x240 RGB TFT with a resistive touch screen
Company: ANTECH
The ANTECH Network Neutron Counter, Model N2000-2 combines Total Neutron Counting, Shift Register Coincidence Counting and Multiplicity Counting in a portable package to provide a state of the art instrument.
Amplifier Technologies Inc
Unit: MOP-TFT800480-50A-IPS
Company: Amplifier Technologies Inc
Website: https://ati-amp.com/
Industrial 5" 800x480 IPS TFT, 1000/cd/m2 sunlight readable display with a resistive touch screen.
- 24bit RGB 5" IPS TFT
- ATIAmp-ATP16.jpg (106.04 KiB) Viewed 66259 times
Blackrock Microsystems
Unit: VK202-25
Company: Blackrock Microsystems
Website: https://blackrockneurotech.com
Using a 20x2 Long-life industrial Serial VFD, with keypad, 12V option.
- 2x20 Serial VFD display, Noritake, CU20029-UW1J
- BlackRockMicro-1.png (123.42 KiB) Viewed 66258 times
