EVE3 & EVE4 Programing Guide v2.4
BT81X Series Programming Guide
BRT_AN_033 Version 2.4
Issue Date: 17-11-2023
Updated the following:
• Change int16_t to uint16_t where it is applicable
• The dest parameter of JUMP/CALL command is changed to number of display list
• Removed the irrelevant chip ID of FT81x
• Fixed the typo of PALETTED4444/565 in PALETTE_SOURCE command
• Added example code for CMD_SETBITMAP
• Added cmd_nop command
• Moved the RST_PULSE host command from ‘after` to `before` ACTIVE host command in boot up sequence.
• Rephrased the note of the SPI clock frequency in boot up sequence.
• Fixed the typo cmd_crc to cmd_memcrc
• Updated the office address of Singapore
BT81X-Series-Programming-Guide_v2.4.pdf
BT81X Series Programming Guide, BRT_AN_033
(3.01 MiB) Downloaded 4914 times
dhruv
Re: EVE3 & EVE4 Programing Guide v2.4
Post by dhruv »
Hello Henry,
I am currently working with an EVE3-50A-BLM-TPN-F32 Display. I want to operate it using an STM32F429ZIT6, and so far, the only library containing the functions mentioned in the programming guide I found was in the GitHub repo for the STM Demo Code, and some of the functions seem to be missing there. Could you provide a link to the complete library of functions mentioned in the programming guide?
Rudolph
Post by Rudolph »
while I am not Henry or working for Matrix Orbital, my library is feature complete: https://github.com/RudolphRiedel/FT800-FT813
And I adapted it to the latest changes.
While there is STM32 support, initialization of the SPI and pins need to be provided.
And I have not implemented DMA support so far as I am not really using STM32 controllers for anything.
