External Mounting
Here are going to be pictures of external mounting of Displays...
Rules:
1. No asking how it was done in this thread, take it to general, or hardware or PM.
2. Please keep the pictures less then 500 pixels (width) in size.
3. Give some information on how it was done.
4. If you need web hosting, please e-mail me and I'll host your pictures.
5. Dead links will be deleted.
6. If you have a homepage with more pictures or details, please give it at the bottom.
Format:
Unit: GLK12232-25
Software: LCDC
Difficulty: Medium
Other: Used the MK2041 to mount it in an external box...
PIC 1
PIC 2
Materials Needed: (list where and so on to help other modders )
ETC...
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-07-10 10:06 ]</font>
<font size=-1>[ This Message was edited by: Henry on 2002-09-12 10:24 ]</font>
Rules:
Format:
Unit: GLK12232-25
Software: LCDC
Difficulty: Medium
PIC 1
PIC 2
ETC...
_________________
Unit: NK204-v
Difficulty: Medium
Other: GPO's are intigrated into the frame, just drill 6 holes for the LED's and another 4 for the LCD, print off a picture and cut the holes for the LCD screen and the GPO's.
Materials Needed:
1x 55p Bent Plexi Photo Frame
6x Various Coloured LED's
2x Schumacher Speed Pack U1546H M3 Caphead Bolts
1x Schumacher Speed Pack U1547I M3 Nuts
1x Schumacher Speed Pack U1548J M3 Nylon Washers
1x cd-rom internal audio cable
2x cables with the connectors on the end from an old pc case
1x aluminimum or plastic pipe to use as a spacer.
6x LED clips
Supplier Links:
http://www.maplin.co.uk
http://www.racing-cars.com
Homepage: AW3K HOME
More pictures and details on my Web Site, Have a look, go on
<font size=-1>[ This Message was edited by: AW3K on 2002-05-06 15:05 ]</font>
Difficulty: Medium
Materials Needed:
6x LED clips
Supplier Links:
Homepage: AW3K HOME
- 06_lcd_side_back[1].jpg (27.12 KiB) Viewed 93157 times
- 02_lcd_stand[1].jpg (33.34 KiB) Viewed 93167 times
unit - LK204-25
Difficulty- Medium
Other - 8 button external remote control with serial cable to PC. Cable carries power to LCD. No GPOs used.
Materials needed -
1. Box - I used UK mains pattress i.e. blank socket box
2. Length of serial cable with male and female connectors.
3. 8 momentary switches.
4. Power connectors.
5. Various tools/saws/files/soldering iron.
Most parts were bought from Maplins
See instructions:-
http://mysite.freeserve.com/winamp_remote
{hosting pics}
<font size=-1>[ This Message was edited by: Henry on 2002-09-13 16:30 ]</font>
Difficulty- Medium
Materials needed -
See instructions:-
{hosting pics}
- mdr_lcd_2[1].jpg (42.51 KiB) Viewed 84234 times
- mdr_lcd_1[1].jpg (35.62 KiB) Viewed 84234 times
Unit: GLK-12232-25-wbl colour modded to bright white
Difficulty: Pretty easy
Other: Meant to get around to putting some buttons in but I gave it away before I had chance!
- 8s.jpg (13.37 KiB) Viewed 93151 times
- 7s.jpg (14.37 KiB) Viewed 93152 times
- 2s.jpg (4.99 KiB) Viewed 93149 times
- 1s.jpg (9.88 KiB) Viewed 93155 times
Unit: LK204-25PC
Dificulty: Medium
First off, please excuse my messy work area. I'm up at my mom's house for 2 weeks and this is my tempory workplace.
I got a LK204-25PC lcd and I decided to make an external case because the computer it will be running on is a family computer and i don't want to go cutting it up. I love the LK204-25PC because it has the cool blue text and white background
. I wanted to be able to control winamp and some other basic functions so i decided on 10 buttons. There is a blue led that is on when winamp is playing and a while led ($5 freakin bucks at RadioShack!) that is on when i have mail. So with that said... on with the pics.
This i the wiring for the switches, it's only half done in this picture.
here's the wiring of the swiches and the leds
here's all the wiring with the lcd installed.
The way I provide the lcd with power is i made 2 plugins on one of an extra pci card slot cover that the lcd plugs in to.
Now for pics of it in action...
here it's showing the song info and the white mail led is lit up.
the white led is so bright that you can see it with the flash on.
some more shots of the song info...
here's my favorite part, the spectrum...
well that's it for now. i'm thinkin of doing something using transparencies like GreatOldONE did over at bit-tech.net.
here's the link to the article http://www.bit-tech.net/article/89/
Dificulty: Medium
- lcd_mail_flash[1].jpg (81.24 KiB) Viewed 84236 times
- lcd_power[1].jpg (39.99 KiB) Viewed 84236 times
- lcd_songinfo[1].jpg (57.58 KiB) Viewed 84236 times
- lcd_songinfo_flash[1].jpg (79.55 KiB) Viewed 84236 times
- lcd_songinfo_withmail[1].jpg (58.5 KiB) Viewed 84236 times
- lcd_spectrum[1].jpg (54.88 KiB) Viewed 84236 times
- lcd_spectrum_flash[1].jpg (75.19 KiB) Viewed 84236 times
- lcd_switchwiring_flash[1].jpg (85.11 KiB) Viewed 84236 times
- lcd_wiring_flash[1].jpg (91.51 KiB) Viewed 84236 times
- lcd_wiring_withlcd[1].jpg (92.45 KiB) Viewed 84236 times
- Ben
C:dos
C:dosrun
rundosrun
C:dos
C:dosrun
rundosrun
Units: GLK12232-25 / LK4041-AT / LK204-PC-25
Difficulty: Medium (Depends on if you have tools or not)
Other: Wood is left over decking from some furniture I was making
Quite a simple system as I needed something that was easy to plug/unplug. So I ripped a slot in some wood, cut plastic to size and drilled holes to hold displays. I then made power/rs232 connectors so they all took the same fitting and made an extension lead from my PC. This means they are on the desktop and easy fo me to access/change for testing purposes in LCDC.
_________________
## # Mat # ##
http://lcdc.planetdps.com
<font size=-1>[ This Message was edited by: mat-d-rat on 2002-07-02 10:30 ]</font>
_________________
## # Mat # ##
- mdr_lcd_1[1].jpg (35.62 KiB) Viewed 84235 times
- mdr_lcd_2[1].jpg (42.51 KiB) Viewed 84235 times
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
Unit: LK202-25-WB
Difficulty: Simple!
Other: Made from Lego Tecnic. Used a length of CAT5 cable to extend the serial and power cables.
Looks way better IRL. Piccys taken at local LAN. I'll replace them with some better ones if I can find them. Was only supposed to be a temp solution until I got the materials for a proper one. But now I like it so much and I've gotten quite a few compliments I think I'll have to keep it.
{hosting pics}
<font size=-1>[ This Message was edited by: Henry on 2002-09-16 15:26 ]</font>
Difficulty: Simple!
{hosting pics}
- image09[1].jpg (60.32 KiB) Viewed 93149 times
- image08[1].jpg (60.11 KiB) Viewed 93159 times
Unit: LK202-25-V
Software: ?
Difficulty: ?
Other: LEDs and Keypad added to box.
my turn !
here's some pics og the project evolution :
Software: ?
Difficulty: ?
my turn !
- moext3.jpg (14.23 KiB) Viewed 93141 times
- moext2.jpg (10.04 KiB) Viewed 93143 times
- moext6.jpg (9.85 KiB) Viewed 93139 times
- moext4.jpg (10.43 KiB) Viewed 93155 times
- moext5.jpg (8.23 KiB) Viewed 93140 times
- global.jpg (20.98 KiB) Viewed 93143 times
http://www.jackypc.com : 1st french website about case moddding. Vive la France !
Pheo's l337 external enclosure :D
Unit: GLK12232-25
Software: LCDC, SLAAKs plugins,
Difficulty: Medium
Other: Graphical MO Ownage
Materials Needed:
V nice GLK12232 from MO (is the l337 IMO!)
Plastic Black Project box (Maplin - Pick one you like)
Switches to match the above
Solder
Ability to use the above
Aluminium for faceplate (Window cutout)
GLK12232-SM Mounted in an external project box, with aluminium mouting thingy! Connected to main PC via old parralel cable. No I'm not going to show you the wiring (its a complete nightmare!).
Difficulty: Medium
Materials Needed:
Solder
- systemdark_joe.jpg (53.66 KiB) Viewed 93148 times
- LCDvisualizer1_joe.jpg (33.68 KiB) Viewed 93143 times
- LCDSysInfo_joe.jpg (16.67 KiB) Viewed 93154 times
- LCDMBM52_joe.jpg (11.92 KiB) Viewed 93144 times
Unit: LK204-25PC
Software: LCDC
Difficulty: Easy...very easy
Other: It's nothing, just wired it up and put it on my desk. Henry forced me to post these, can I have my caffeine back now please Henry? PLEASE?
More pics on http://users.pandora.be/relix/digicam/LCD
Software: LCDC
- image09[1].jpg (60.32 KiB) Viewed 93162 times
- image08[1].jpg (60.11 KiB) Viewed 93144 times
...whatever, as if I care...
Unit: LK204-25-PC
Software: LCD Control by Sandy Barbour
Difficulty: Easy
Other: Used as programmable data readout for flight simulation
software.
General materials list
3 -12v, 20 Ma LCD lamps
2 - Momentary switches
1 - Radio Shack basic plastic enclosure
3 - 1x2 0.10" connectors
1 - 1x4 0.10" connectors
4 - standoffs w/hardware
1 - 4 wire ribbon cable (36") for power connection
Full details and required software can be found at:
http://www.digital-flight.com
Difficulty: Easy
software.
Tony Gondola
Digital-Flight
Digital-Flight
Unit: NK204-v
Difficulty: Medium
Other: Made from a Lian-Li Mouse Mat and some bent perspex.
The Mouse Mat
Materials Needed:
1x Lian-Li Mouse Mat
6x LED clips
Supplier Links:
Homepage: AW3K HOME
Difficulty: Medium
The Mouse Mat
Materials Needed:
6x LED clips
Supplier Links:
Homepage: AW3K HOME
- mm_mat.jpg (22.81 KiB) Viewed 93138 times
- mm_side_gpo.jpg (33.19 KiB) Viewed 93150 times
- mm_back_gpo.jpg (33.04 KiB) Viewed 93151 times
- mm_front.jpg (21.95 KiB) Viewed 93144 times
- mm_back.jpg (25.37 KiB) Viewed 93150 times
- mm_front_light.jpg (18.33 KiB) Viewed 93152 times
- mm_gpo_on_dark.jpg (15.44 KiB) Viewed 93152 times
Unit: LCD2041-WB-V
Software: LCDC
Difficulty: Easy-Medium
Other: Want to add more GPO's using the parallel port
I used a medium size plastic project box that I have it CNC Machined for 5$
I used a 7 conductors wire..(20ft).. 3 for data 2x2 for power... standard DB9+Molex at the end for compatibilty on other computers.
Changed the bolts and nut on the lcd for mounting.
Software: LCDC
- Mo005.JPG (22.75 KiB) Viewed 93154 times
- Mo004.JPG (35.75 KiB) Viewed 93139 times
VFD2041-V -- System Status -- Internal
LK402-12-V -- MP3 Remote -- External
LCD2041-WB-V -- 2nd System Info -- Not installed
