A Gallery of pictures...
ATX Networks
Unit: BLK202A
Company: ATX Networks
Website: https://atx.com
5.25" Computer USB LCD with keypad HMI
ATX Pilot Carrier.jpg (53.52 KiB) Viewed 68087 times
SEAL Analytical Limited
Unit: LK204-25
Company: SEAL Analytical Limited
Website: https://seal-analytical.com
Using our LK204-25 Industrial Serial LCD with a keypad interface.
The SEAL Analytical Digestion Block is your key to successful kjeldahl digestions. The BD50 Digestion Block automates acid digestions for up to 50 laboratory samples simultaneously. It is ideal for Total Nitrogen (TKN) and Phosphorous (TP) digestion.
20x4 Serial LCD with keypad
Seal Analytical BD50 0313.jpg (359.63 KiB) Viewed 68083 times
Noisecom
Unit: HTT70GA-TPC
Company: Noisecom part of Wireless Telecom Group
Website: https://www.noisecom.com/
Noisecom using our Industrial 7" HDMI Display with USB touch.
7.0" HDMI TFT
7.0" HDMI TFT
The Noisecom UFX7000B broadband AWGN noise generator has a powerful single board computer with flexible architecture used to create complex custom noise signals for advanced test systems. This versatile platform allows the user to meet their most challenging design requirements. Precision components provide high output power with superior flatness, and the flexible computer architecture allows control of multiple attenuators, switches, and filter banks.
NSI Inc
Unit: https://www.matrixorbital.com/lk162b-7t
Company: NSI Inc
Website: https://nsystems.com
The LK162-7T is a 16x2 intelligent LCD display designed to fit into 1U form factors. Engineered to quickly and easily add an elegant graphic HMI to any application. Multiple communication protocols such as Serial RS232, TTL, I2C, and USB communication modes allow the LK162-7T LCD to be connected to a wide variety of host controllers.
16x2 LCD 1U HMI with Serial RS232, TTL,USB, I2C with a 7 key backlit Tactile Keypad and 3 LED's 5V RGB Backlight
RF Instruments LLC
Unit: GLK19264A-7T-1U
Unit: LK162B-7T
Company: RF Instruments LLC
Website: https://www.rfinst.com/
2U 19” Rack Mountable Wideband Up –Down Converter High Performance Frequency Extender
192x64 Graphic LCD, Serial 1U Display
16x2 Serial LCD, 1U Display
MVG
Unit: LK204-25-IY
Company: Microwave Vision Group
Website: https://www.mvg-world.com
The AL-4164 and AL-4166 programmable controllers offer real-time control of positioning subsystems used in near-field and far-field antenna measurement systems. They may be configured to drive planar scanners and general purpose far-field positioners that are encoder-based or involve simultaneous motion.
20x4 Serial LCD
20x4 Serial LCD
Engineered Compost Systems
Unit: LK202-25
Unit: BEZ-202C
Company: Engineered Compost Systems
Website: https://compostsystems.com
Professional bezel for industry standard 20x2 / 2x20 LCD, VFD or OLED displays. ABS construction, with a lexan window combined with our serial 20x2 LCD.
20x2 LCD Bezel
20x2 LCD Bezel
Compost Systems-2.png (1.37 MiB) Viewed 66236 times
2x20 Bezel
2x20 Bezel
Compost Systems-1.png (891.01 KiB) Viewed 66236 times
Omniverter
Unit: BEZ-204A
Company: Omniverter
Website: https://www.omniverter.com/
Professional bezel for industry standard 20x4 / 4x20 LCD, VFD or OLED displays. ABS construction, with a lexan window.
20x4 LCD Bezel
20x4 LCD Bezel
LDetek
Unit: LK162A-4T
Company: LDetek
Website: http://www.ldetek.com/
The LK162A-4T is a tri-color software controlled backlight, that will allow the user to set the colour of the characters on a black background.
The LDPMS is a stand-alone pressure monitoring system design to monitor the pressure of a gas source. It can monitor up to 2 gas sources simultaneously and generate an independent low-pressure alarm when the pressure level of a source is below its setpoint
16x2 LCD, small profile
2x16 Serial LCD with keypad
Safety Vision
Unit: ELK204-7T-GW-MT
Company: Safety Vision
Website: http://www.safetyvision.com/
External 4x20 LCD in an industrial metal enclosure, 3 dual color LEDs, 7 key backlit keypad, custom silk screening.
External USB 20x4 LCD
GOMA ELETTRONICA SpA
Unit: BGK19264A-BK
Company: GOMA ELETTRONICA SpA
Website: https://www.goma.it/en/
A 5.25" 192x64 LCD in a 1 U bracket, 7 key backlit keypad, 3 dual colour LED's, Serial, I2C, RS422 or USB interface.
5.25" drive-bay LCD
5.25" drive-bay LCD
Kaman Precision Products
Unit: LCD0821
Company: Kaman Precision Products
Website: https://www.kamansensors.com
The Most Advanced Digital Variable Impedance Transducer for Noncontact Linear Position / Displacement / Proximity Sensing
8x2 Serial LCD
8x2 Serial LCD
2x8 I2C LCD
2x8 I2C LCD
ANTECH
Unit: MOP-TFT320240-35A
Company: ANTECH
Website: https://www.antech-inc.com
Industrial long term 3.5" 320x240 RGB TFT with a resistive touch screen
The ANTECH Network Neutron Counter, Model N2000-2 combines Total Neutron Counting, Shift Register Coincidence Counting and Multiplicity Counting in a portable package to provide a state of the art instrument.
320x240 RGB 3." TFT
320x240 RGB 3." TFT
Amplifier Technologies Inc
Unit: MOP-TFT800480-50A-IPS
Company: Amplifier Technologies Inc
Website: https://ati-amp.com/
Industrial 5" 800x480 IPS TFT, 1000/cd/m2 sunlight readable display with a resistive touch screen.
24bit RGB 5" IPS TFT
Blackrock Microsystems
Unit: VK202-25
Company: Blackrock Microsystems
Website: https://blackrockneurotech.com
Using a 20x2 Long-life industrial Serial VFD, with keypad, 12V option.
2x20 Serial VFD display, Noritake, CU20029-UW1J
