I have question about the Rx/Tx Receive and Transmit LED output connectors on the LK202-24 USB.
Can you connect LED's them to see when the display receives/sends data, if so what voltage is it, if this is not the use then what is it for?
Rx/Tx Receive and Transmit LED outputs
Asus P4B533-E / P4 2.53@2.66
yes, you can plug in a LED straight, one will show Rx and the other will show Tx. The pins all ready have current limiting resistors.. so pretty much any standard size LED will work fine. (it's limited to 20mA in case your wondering).
This is what I did to this case... each LCD has a LED attached to it.
Thank you for the information, wish I had known before I had made my panel, I would have added the two LED's.
Can you tell me how to post a picture as part of a message, as I would like add one or two pictures to the gallery form.
I have used a 4" bay to hold 6 switchs and 6 LED's and a 5 3/4" bay to hold the MX202 that I have removed from the bracket and mounted it into a Lian Li blank panel, looks good
to post an image do this
[ img ]http://www.matrixorbital.com/picture.jpg [ /img ]
remove the spaces by img... looking forward to the pics
you need to have the picture hosted somewhere...
if you need hosting e-mail me henryj@matrixorbital.com
