Installing mx212
Installing mx212
I got a MX212 and im wondering what the correct way is to get the unit into my drive bay. The two screws on each side screw into what? The thread that explains this has the images missing. I just cant figure out how this fits in to make it tight with the use of these screws.
Think of the screw holes on either side like the screw holes on a cd rom. If you mount a drive in your case using screws directly through the drive bay into the drive then it should be apparent how to do this. Since you don't see this right off then possibly you are using drive rails to mount your drives. In that case you will need to mount the display to drive rails and install the rails into your PC. Hope this helps you.
