how to install Tempature Probs
pawn
Post by pawn »
i got the dallas temp probs, and i got them hooked up to the display..
Whats the Best way to attach to probs.. I have 3 Water Cooling Blocks on my PC. I tried Taping but it dont hold, whats the best way to make them stick or hold without messing up the tempautre reading...
Pawn
Johnny
Post by Johnny »
I use a tiny drop of super glue. You can easily remove the sensor with a small watch screwdriver without any damage, at a later date. You can also use heat prove tape which is quite strong, only thing i can't see anywhere you would be able to buy it.
pawn
Post by pawn »
should i take a tiny drop of super glue on the flat part of the sensor or, put the sensor flat on the water block then place super glue over the top?
Johnny
Post by Johnny »
A pin head on the flat surface, and press this to a flat surface on your waterblock. :wink:
pawn
Post by pawn »
thanks man
