Dear All,
I'm using a micro-controller (TTL levels) to write on my VFD display.
Is there a way to directly wire the TTL signal to the display without performing a TTL->RS232 conversion before ?
I can see that the DB9 plug on the display is connected to a SP232 chip that performs the RS232->TTL conversion but I can't find where the TTL signal is available to solder a wire.
When looking at the PCB board, above the SP232AEN chip, I can see 2x4 solder pads. See picture.
Can I solder the column 2 and 4 and unsolder columns 1 and 3 to bypass the RS232->TTL converter with no danger ?
Thank you. I did it and it works correctly.
I also soldered an other pad to supply 5V through the DB9 plug. The user manual indicates we can do this but it was not working.
Do you have a 5V or a 12V display? If you have a 12V module, you need to power up the display at the DB9 connector with 12V. It will have a 3 terminal 78M05 regulator, if it was a 12V module.
