I have searched this forum and read all the docs I can find. I'm still confused about how to hook up a led to this rev 1.4 LCD.
I have managed to get the Dallas temp sensor to work and hooked up 2 different fans to the hi powered GPO's. My LCD doesn't look like the one in the PDF file.
Mine has a row of 4 white colored 3 pin connectors (WOL). This is where I have my Dallas sensor plugged in.
Next to it is a row of 3 brownish red colored 3 pin fan type connectors. This is where I have hooked up my fans.
There is a group of pins that might be the internal USB hookup.
There is a group of pins that have "trx" and something I cant remember. I think these are serial connections?
I have to assume all this is correct since everything works as expected. Sooooo..........
Where are the 5 volt low powered connectors that are under software control?
I have a server PC case with 3 extra leds, one for fan failure, two for temperature warning.
Hardware = LK202-24-USB Rev1.4 or is it a MX214
Thanks BRB
