I'm in the process of building a mini-itx system using a Via Epia MII10000 Main board. I want to add a nice matrix orbital 20x4 Character LCD and don't know which one to choose.
It's seems that the easiest chouse would be going with the LK204-24-USB, but it's the expensiest one.
I noticed that via epia MII10000 boards come with a I2C conexion, which I understand is supported with matrix orbital lcds too. Could I go with the LCD2041 conecting it to the I2C conexion and be able to fully use LCDC?
PS: This seems to be I2C pin layout for the MII10000:
1 +3.3 V
2 +3.3 V
3 EL-ON
4 SMBCK
5 SMBDT
6 GND
Noob I2C question and LCD2041
Hi Larcho,
If you get the LCD2041 you will be able to use I2C, but not in conjunction with LCDC. LCDC uses RS-232 communications which is through the serial com port. You will also need to program your own program if you were to communicate via I2C because of that reason. I suggest you go connect it through the serial com port, if you were to use LCDC. That way you will be able to get a less expensive display, and you can use LCDC.
