I'm not sure what has gone on here but perhaps you have seen this before...
Something funny is going on, I went off for 2 weeks and the computer was off and the MO was working fine. When I came back my missus had used it and the display wouldn't show any characters.
The machine would only have been on for about a day or so at the most. and I know for a fact that there is no way she would/could have taken the back off and touched it.
The Matrix orbital GPOs and the backlight are working fine with all the software but it is as though the display has forgotten how to produce characters.
I switched the whole thing off and turned on again last night but that didn't fix anything, I haven't had a chance to test anything else with it yet. When I get home tonight I'll see if a good night's sleep has fixed it. (!)
Have you ever seen this happen before?
Thx
kazza
<font size=-1>[ This Message was edited by: Dr_kazza on 2002-02-11 03:14 ]</font>
Character Display gone...
Is there a contrast setting that will SAVE or a backlight one as well? I noticed from software to software it will mess up my backlight (ie turn it off on my VFD) or mess up my contrast.
Also, shouldn't the contrast be called brightness? That's all it does on my VFD, make it brighter. Is it bad to have it too high? Will it burn out?
What is the life of my VFD if I leave it on 24/7?
Can I hook the VFD to a baybus to turn it off? What happens if I do? Will it mess up? On and off?
I thought the contrast of lcds was controlled differently from the brightness of vfd's (in software I mean) - though I don't have an MO VFD so I can't help you...
As for lcd's it should be called contrast yes, and the program (contrast) that henry mentioned does save the contrast setting... that's the point of the program.
As for putting a vfd on a baybus (I take it you mean so you can just turn it on/off and not so you can control it's brightness) - that should be fine (might mess the display up on first turn on but shoudl recover on first refresh, though I'm not sure.
If you want to control the brightness of a vfd using a rhebus it's not very simple - see the manual for why (you have to vary the pulse width).
r.
r.
No there is no brightness control for vfd's. They all call it contrast. I don't want to control brightness through a baybus. I only want to turn it on and off because I am not sure of it's lifespan. Pulse width!? Ha, child's play. (uh what is a pulse width?)On 2002-02-11 13:01, TheCheeseMan wrote:
r.
- LCD!
