temp probes
temp probes
how could i use my temp probe to measure my water temp in my water cooling setup?
LOUnyc,
The temp probes are not water proof, however, you may be able to use them in water if you cover it with epoxy on the entire sensor and any wire connection involved. You will then need to set up LCDC to read the temperature sensor.
You can find the temperature probe at http://www.matrixorbital.com/product_in ... an-cooling
