FANS
FANS
Thanks for the fast reply. The LCD unit is working and LCD is on and running. I purchased a second floppy connector to work in my Ultra XCONNECT power supply so i can uses my floppy unit and my MX4 unit. All fans are connected to the MX4 fan side of the unit.Is there something more i must do to keep the fans running? modifly something?or ...thanks
There is a jumper above the floppy power connector. You must make sure the jumper is placed on the two left pins. Overall, to keep the fans running after you have the right connections is to program them.
For more detailed information on the unit, you can refer to the manual at http://www.matrixorbital.ca/manuals/LK_ ... 04-24-USB/
Let me know if you have anymore problems.
