hello
I have 3 lcd4041 and one mx412 displays. Basically what can I do with this? Is it possible to use multiple displays? also does anyone know what size screws the mx412 is mounted with I dont have the original mounting hardware.
thanks for any help
multiple displays? using lcdc?
hi ghost2501,
It is possible to use the multiple displays. The 3 displays won't be linked together though. They are controlled independantly. Aslong as you have the available comports, you can place them all in the same pc. The MX412 will definitely fit into your pc because it creates a virtual com port. If you have room for all the units, you just need to open 4 instances of LCDC.
The size screw used for mounting the MX412 is 4-40 5/8" screws.
