Connector for MOP-GL12232D-BGFW
Michael Zoran
Post by Michael Zoran »
I'm a hobbiest and bought the MOP-GL12232D-BGFW to play with because I want to display arbitrary graphics with my project and none of the serial devices seem to have this ability(some allow you to upload bitmaps into EEPROM, but that isn't exactly arbitrary graphics in my opinion). I assume the reason none of the serial devices support this is because a serial connection doesn't have enough bandwidth to constantly upload full screens.
Anyway, I'm alittle stuck by the connector. It's alittle on the small side to put on a breadboard or to solder wires to each pin. Is a cable available somewhere that I can cut or do I pretty much need to design a custom PCB and get it manufactured at some a boardhouse($60-$80) just to do some prototyping?
Hi Michael,
It's a pretty difficult task finding a connector for the pins. The spacing is 0.05inches. Your best bet is to get a pcb specially made for the pins.
Michael Zoran
Are you sure you don't mean 20mil or .020 inches? The number you quote is very small.
sorry, I meant to put 0.05 inches.
Michael Zoran
Is it possible to get the full mechanical specifications for the connector. The pin spacing, the pin size, and the distance of the connector from the edge of the display. Also, I noticed that the display has some tabs that look like that are ment to go through holes on the PCB and get hot glued in place. Can I get the size and position of these holes.
Otherwise, it looks like it might be required to use a digital caliper on the unit to get all the measurement, but this seems alittle error prone and it cost $$ for every PCB.
I saw a mention of a MOI series for two wire. With this series be cost effective and allow displaying arbitrary graphics at high speed without trashing the flashram of the display. Basically, I want to write my own GUI interface. I also want to display complex graphs that get updated at least 10 times per second in realtime.
Hi Michael,
You can get the mechanical layout of the display on page 14 of the manual at http://www.matrixorbital.ca/manuals/MOP ... 12232D.pdf
