Since the GPOs are open collector outputs, can one be used to sink a 12v @ 7ma beeper?
Using an external supply not connected to the display except for the common, of course.
Kurt
VK204-25 GPO Question
Hello kfaria,
Thanks for your post.
First of all, the VK204-25 modules do not have open drain GPOs. The GPOs on the VK204-25 can only source or sink 20mA at 5V. We offer open drain GPOs (called advanced GPOs) on our USB modules. And these open drain GPOs are limited to 12V, 1A, which is definitely enough for the beeper you are thinking of using.
I hope this helps.
I hope this helps.
Hello kfaria,
Too bad. But another option that I can think of is connecting a fet at the output of the GPO, the logic will be different but then it can definitely handle the requirements for your beeper. If you want to explore that option, I can help you with that.
Good luck.
Good luck.
Thanks for your offer, but interposing another FET will be easy, if I decide to go that route.
This is my last product using an MO display, LK204-25.
http://www.catheterholes.com/machines/a ... llerLT.asp
The next product will use a VK204-25, much easier to see.
