Hi All,
When I setup my temperature screens in screen builder for my MX412, the 4th line lines up with lines 2-3 when temp is below 100F. Once it gets above 100F, the fourth line is offfset one block to the right. When I space the 4th line in screen builder to display properly to the left when reading is over 100F, it is wrong when the temp goes below 100F. I have tried to set up alignment left, middle/center and offset formula with an addtional space in configuration.
What can I do to keep the 4th lines consistent for both over and under 100F?
camman
