after dragging my build out for what seems like a lifetime, im finally gettingf round to finishing it.
basically i have an MX4 plugged into the USB header.
and it isnt detected by LCDC. i can get some features to work,weather, winamp, RAM use. but as a result of it not being detected it always shows my temp as overheating, and cant controll my fans on my radiators, or water pumps, they just run max rate all the time.
Also i cant access the 2 cpu temps (i run dual xeons), it detects i have 2, but doesnt isplay them.
should i give up try and find my serial lead? or is there something i should do for the usb?
LCDC and USB
Thats strange that it wouldn't be detected. I recommend two things, uninstall LCDC, and install an updated version from LCDC.cc, and then unistall your drivers and install updated drivers from our website. After you have done this, try and see if you can get LCDC to detect it.
If not, try LCDC.cc forums, they may know a work around to help you that I'm not aware of.
Jon
Jon
