Large digits on GLK12232-25-SM
JacquesB
Post by JacquesB »
I have a GLK12232-25-SM rev 1.4. I needed a very large font (only digits) that would occupy appox 3 rows.
I've drawn 10 22x16 digits using MSpaint. I used MOGD software to download them to FONT 3 but
when I write to the display I only get garbage on the screen.
On the Font tab of MOGD I can see the different characters but some how they don't get formatted correctly.
I also tried MOGD Sharp software and I get the same results. I can also view and edit individual characters but
they don't get thru the display
Also Is ther some sort of a manual or help file for MOGD or MOGd Sharp?. Some parameters require some explanations.
Can you help?
Thanks for your support
Ldgits.zip
Zip file contaning font
(6.64 KiB) Downloaded 652 times
There was a small mistake in the mgf file, It defined the characters a different size then the actual bmp's where. I Fixed the file for you, enjoy!
LDigits_fixed.zip
(6.48 KiB) Downloaded 541 times
JacquesB
Post by JacquesB »
Ray,
It works fine, I tought that I had designed characters 22x16 but they were 19x14. My mistake
Thanks Ray
