C++ OrbitalDisplay Class
yakpimp
Post by yakpimp »
I got my first display yesterday, and it is sweet, but I wanted a simple way to interface with it using c++.
I saw someone had written an sdk using c#, but I don't use that, so I figured why not write my own...
It's basically just a class that you can instantiate and then use things like myDisplay.PrintText("I like hotdogs"); and myDisplay.SetCursorPos(4, 3);
This is my first version, so I haven't yet put in the stuff for using keypad input, but most of the main commands can be sent very easily.
http:\\www.kmcgrail.com\OrbitalDisplay.zip
So to use it, basically just put include the header. And then create an instance of OrbitalDisplay and use it's included functions.
This little sample just draws 4 Horizontal graphs accross the screen a few times. There is a blocking pause function added so animation can be done.
#include <OrbitalDisplay.h>
int main(void)
	OrbitalDisplay myDisplay;
	myDisplay.InitDisplay("COM3");
	//myDisplay.ToggleLineScroll(FALSE);
	//myDisplay.ToggleCursorBlinking(FALSE);
	//myDisplay.ToggleCursorUnderline(FALSE);
	myDisplay.InitHorizontalBarGraph();
	for(int i = 0; i < 400; i++)
		myDisplay.DrawHorizontalBarGraph(1, 1, HORIZ_LEFT_TO_RIGHT, i%100);
		myDisplay.DrawHorizontalBarGraph(2, 20, HORIZ_RIGHT_TO_LEFT, i%100);
		myDisplay.DrawHorizontalBarGraph(3, 1, HORIZ_LEFT_TO_RIGHT, i%100);
		myDisplay.DrawHorizontalBarGraph(4, 20, HORIZ_RIGHT_TO_LEFT, i%100);
		myDisplay.Pause(0.05f);
	return 0;
Here is the header that shows what functions are currently available
// Function:	InitDisplay()
// Purpose:		Creates the handle to the display COM port
//				initialized default display values.
// Parameters:	char* _szComPort	-> COM port display is connected to.
// Return:		BOOL			-> Did we get a handle to the port
BOOL InitDisplay(char* _szComPort, DWORD _dwRows = 4, DWORD _dwColumns = 20);
// Function:	SendCommand()
// Purpose:		Sends a command to the COM port using WriteFile
// Parameters:	DWORD _dwCommand -> The command to send
//				DWORD _dwParam1	-> First parameter to command
//				DWORD _dwParam2	-> Second parameter to command
// Return:		None
void SendCommand(DWORD _dwCommand, DWORD _dwParam1 = -1, DWORD _dwParam2 = -1, DWORD _dwParam3 = -1, DWORD _dwParam4 = -1);
// Function:	PrintText()
// Purpose:		Prints the string passed in to the current cursor
//				position on the oribital display.
// Parameters:	char* _szString		-> The string to print
// Return:		None
void PrintText(char* szString);
// Function:	SetCursorPos()
// Purpose:		Sets the current cursor position on the display
//				(Row, Column)
// Parameters:	DWORD _dwRow	-> Row to move to
//				DWORD _dwColumn	-> Column to move to
// Return:		None
void SetCursorPos(DWORD _dwRow = 0, DWORD _dwColumn = 0);
// Function:	SetCursorPosCR()
//				(Column, Row) for those people who are backwards
// Parameters:	DWORD _dwColumn	-> Column to move to
//				DWORD _dwRow	-> Row to move to
// Return:		None
void SetCursorPosCR(DWORD _dwColumn = 0, DWORD _dwRow = 0);
// Function:	ToggleCursorUnderline()
// Purpose:		Toggles if the underline cursor is turned on or off
// Parameters:	BOOL _OnOff		-> TRUE(on) FALSE(off)
// Return:		None
void ToggleCursorUnderline(BOOL _OnOff = TRUE);
// Function:	ToggleCursorlinking()
// Purpose:		Toggles if the blinking block cursor is turned
//				on or off
// Return:		None
void ToggleCursorBlinking(BOOL _OnOff = TRUE);
// Function:	CursorMoveLeft()
// Purpose:		Moves the current cursor position to the left
//				by _dwHowManySpaces
// Parameters:	DWORD _dwHowManySpaces	-> How many spaces to move
// Return:		None
void CursorMoveLeft(DWORD _dwHowManySpaces);
// Function:	CursorMoveRight()
// Purpose:		Moves the current cursor position to the right
// Return:		None
void CursorMoveRight(DWORD _dwHowManySpaces);
// Function:	ToggleBacklight()
// Purpose:		Toggles the units backlight.
// Parameters:	BOOL _OnOff		-> TRUE(on), FALSE(off)
// Return:		None
void ToggleBacklight(BOOL _OnOff = TRUE);
// Function:	ToggleLinewrap()
// Purpose:		Toggles line wrapping at the end of each line. Not
//				word wrap.
// Return:		None
void ToggleLineWrap(BOOL _OnOff = TRUE);
// Function:	ToggleLineScroll()
// Purpose:		Toggles line scrolling when the end bottom of the
//				display is hit.
// Return:		None
void OrbitalDisplay::ToggleLineScroll(BOOL _OnOff);
// Function:	SendCursorHome()
// Purpose:		Sets the cursor to the top left corner of the display
// Parameters:	None
// Return:		None
void SendCursorHome();
// Function:	SetContrast()
// Purpose:		Sets the contrast of the display
// Parameters:	DWORD _dwContrast	-> Contrast amount (0->255)
//				BOOL  _bSave		-> TRUE(Save), FALSE(Do not save)
// Return:		None
void SetContrast(DWORD _dwContrast, BOOL _bSave = TRUE);
// Function:	SetBacklightBrightness()
// Purpose:		Sets the Backlight Brightness of the display
// Parameters:	DWORD _dwBrightness	-> Brightness amount (0->255)
// Return:		None
void SetBacklightBrightness(DWORD _dwBrightness, BOOL _bSave = TRUE);
// Function:	ClearDisplay()
// Purpose:		Clears the entire display
// Parameters:	None
// Return:		None
void ClearDisplay();
// Function:	Pause()
// Purpose:		Pauses everything, useful for animations, (BLOCKING)
// Parameters:	DWORD _dwSeconds	-> Number of seconds to pause
// Return:		None
void Pause(float _fSeconds);
// Function:	InitHorizontalBarGraph()
// Purpose:		Initializes horizontal graph
// Parameters:	None
// Return:		None
void InitHorizontalBarGraph();
// Function:	DrawHorizontalBarGraph()
// Purpose:		Draws a horizontal graph
// Parameters:	DWORD _dwRow		-> Row to draw in
//				DWORD _dwColumn		-> Column to start drawing in.
//				DWORD _dwDirection	-> HORIZ_LEFT_TO_RIGHT or
//									   HORIZ_RIGHT_TO_LEFT
//				DWORD _dwLength		-> Length in pixels of the bar
// Return:		None
void DrawHorizontalBarGraph(DWORD _dwRow, DWORD _dwColumn, DWORD _dwDirection, DWORD _dwLength);
// Function:	InitVerticalBarGraphNarrow()
// Purpose:		Initialized narrow Vertical bar graph
// Parameters:	None
// Return:		None
void InitVerticalBarGraphNarrow();
// Purpose:		Initialized wide Vertical bar graph
// Parameters:	None
// Return:		None
void InitVerticalBarGraphWide();
// Function:	DrawVerticalBarGraph()
// Purpose:		Draws a vertical graph
// Parameters:	DWORD _dwColumn		-> Column to drawing in.
//				DWORD _dwHeight		-> Height in pixels of the bar
// Return:		None
void OrbitalDisplay::DrawVerticalBarGraph(DWORD _dwColumn, DWORD _dwHeight);
Thanks very much for your post. I am sure it'll be of good help for those who might need it.
yakpimp
Post by yakpimp »
I will be working on this quite a bit more when I get my new display. It's a bit rough doing testing on a display that doesn't respond 100% correctly, but no worries, great things take time. :)
