Run Playlist without LCDStudio
Remek
Post by Remek »
HI
Is there way to run playlist on GX without keep running LCDStudio. I need make it run right after computer started, without option to close it.
Regards,
Remek
Go into the options panel and select your prefered startup mode and default playlist and you should be fine :)
Remek
Post by Remek »
Thanks for advice. Unfortunately when I closed LCDStudio it goes to tray icons so then from context menu I select exit and my list stop play.
I need make it invisible before other user so no one can close it other way then kill process under Task Manager.
Regards,
Remek
Thats a usecase we have never considered before and therefore is not supported at this moment in time. Your sugestion will be taken in consideraion for future versions.
