Hello, I am using Windows XP Professional. I had a problem with the baud rate seeing as my PIC18F2685 would send data to it and it would not display the characters and numbers I wanted. I used the jumper as data sheet given, i reset the LCD (LK162-12_220) to the factory settings. I changed the baud rate to 9600 which I wanted to do. The only problem is that everytime I unpower the LCD and repower it, what appears on the screen are the same random characters. I can clear it using the uproject but nothing can be changed and the baude rate returns to factory setting. I tried manually overriding the LCD using both the steps on the manual and on the new LK12 manual from the Matrix Orbital website. I don't know how to save the settings that I set using the Tuner. I went to the forums and saw that one way would be to sent a Start Remember, change the settings and a Stop Remember and then execute. still same problem, I'm trying to use the RS232
my board Rev is 3.0 model of the lcd is LK162-12
When i got the LCD it work perfect, but two weeks before it start to give me this problem, so can anybody help me to slove this problem please...
i thought it is problem with my C program,so i test my program with my buddy's LCD, it is working........ so it something wrong with LCD...
