From time to time my system becomes slower then usual, I check and see why: DriverCoreSvc.exe is at about 50% CPU usage. Tried to restart the service - comes back to 47-50% again.
Any ideas?
DriverCoreSvc.exe at 50% CPU usage
- drivercoreservice-50percent.JPG (59.64 KiB) Viewed 8122 times
Ray:
It seems I narrowed down the condition when the service jumps high - it happens when nothing is enabled in Displays tab in GX Management Console. When I select Media Center or Clock or CPU Load, the CPU usage goes down to the minimum 00-01. I am not sure now what was my lowest CPU with nothing selected before, but today it is constantly between 47 to 50% with nothing selected.
Since I use MediaPortal which takes care of everything, I am not quite interested in any of your default selections, but zero selection overloads my CPU.
Can you verify what is the lowest CPU load with nothing selected on your PC?
