LK204-7T-1U-LV (low voltage) TTL serial voltage levels
duck
Post by duck »
We're looking at using an LK204-7T-1U-LV (low voltage) display in an embedded project. We'll be driving it over serial with an Atmel XMega AVR, with Vcc=3v3.
It's not clear to me what the "TTL" voltage level for this display is. Is the serial voltage threshold low enough for me to communicate directly from the AVR's uart pins (3v-ish, I'm guessing), without the need for a level shifter?
--duck
Hello duck,
TTL levels for the LK204-7T-1U-LV is 0 - 3.3V.
You do not need level translator since you will be using same voltage levels.
