LK202-25 keypad HOWTO?
cptdondo
Post by cptdondo »
This should be simple, but I cannot get any response from the keypad with my LK202-25.
I have a B202A-BK, and I connected it to the keypad header. I get no response when I push anything on the keypad. Just to make sure I reset the keypad settings using the following:
#!/bin/sh
echo -e "\xFE\x58"
echo -e "\xFE\xCA\xF5\xA0\x00"
echo -e "\xFE\x93\x01"
echo -e "\xFE\x41"
echo -e "\xFE\x55\x08"
echo -e "\xFE\x7E\x00"
echo -e "\xFE\xD5ABCDEFGHIJKLMNOPQRSTUVWXYabcdefghijklmnopqrstuvwxy"
echo -e "\xFE\x93\x00"
echo -e "\xFE\xCA\xF5\xA0\x18"
so characters should be sent immediately.
I am centering the keypad connector on the header. I can't find any docs on the BK202 keypad connector.
cptdondo
Re: LK202-25 keypad HOWTO?
Post by cptdondo »
OK, got it figured out.... Make sure canonical mode is not set for the serial port.
stty -F /dev/ttyS0 -icanon
or
newtio.c_lflag = 0;
if you're working with *nix.
Hello cptdondo,
Glad to see you have that keypad working now. For future reference you can find the schematic layout of the 7-key B202A keypad here, and the header pinout in the LK202-25 manual.
All the best with your project, if you do run into any further questions as you continue development, please don't hesitate to ask.
