GLT240128 Interface options
Absimpson
Post by Absimpson »
I would like to use the serial pins on the GLT240128 to communicate to a gumstix processor. However, I want to solder the pins instead of using the normal connectors. Could I order the USB option (it looks like the connectors for the serial pins are still there but without the connector) and do this?
Thanks!
Tino
Re: GLT240128 Interface options
Post by Tino »
If you are looking to communicate with you display via the serial you will need to order a serial unit. We could look into a custom serial unit without the connections though.
Thank you
Martino
Martino DeLeon
