LK204-7T-1U custom character
user8547
Post by user8547 »
I can't seem to create and display a custom character on my LK204-7T-1U display. (weird signs appear)
here's my code for the degree " °c " example from the manual page 21.
//LK204-7T-1U
byte degree[8] = { 00001000, 00010100, 00001000, 00000011, 00000100, 00000100, 00000011, 00000000 };
void setup()
  ClearLCD();
  Serial1.begin(19200);//serial1 port  for  communication with my arduino
void loop() {
ClearLCD();
CursorPos(1,1);
createchar();
 delay(20000);
void createchar(){
  Serial1.write(254);
  Serial1.write(78);
  Serial1.write(1); //Character ID, value between 0 and 7
  Serial1.write( degree[8]); //character pixel data
void ClearLCD(){
  Serial1.write(254);
  Serial1.write(88);
void CursorPos(int xpos, int ypos){
  Serial1.write(254);
  Serial1.write(71);
  Serial1.write(xpos);
 Serial1.write(ypos);
Am I doing something wrong?
Re: LK204-7T-1U custom character
Hi user8547,
The implementation of your createchar function looks good, until the last line. You are only transmitting a single byte, which is the uninitialized ninth value or your degree array. You might try the following:
Serial1.write(degree, sizeof(degree));
Also, please note that Serial.write expects a byte, string, or byte array parameter, so you may experience undesirable behaviour within your CursorPos function.
user8547
Post by user8547 »
solution:
//LK204-7T-1U
//byte degree[8] = { 00001000, 00010100, 00001000, 00000011, 00000100, 00000100, 00000011, 00000000 };
byte degree[8] = { 8, 20, 8, 3, 4, 4, 3, 0 };//changed bytes to decimals
void setup()
  ClearLCD();
void loop() {
ClearLCD();
CursorPos(1,1);
createchar();
 delay(20000);
void createchar(){
  Serial1.write(254);
  Serial1.write(78);
  Serial1.write(degree, sizeof(degree)); //character pixel data
  Serial1.write(1); //repeat Character ID to actually display it on the LCD screen
void ClearLCD(){
  Serial1.write(254);
  Serial1.write(88);
  Serial1.write(254);
  Serial1.write(71);
Thanks Mr Clark
No worries user8547, glad to see your code is running. Thanks for posting the solution.
